R56 JCW Remove oil cap = Bad idle p
I have a vacuum issue. Loads of vacuum. Oil cap is sucked down. Remove oil cap the engine has bad idle and can die. Already changed valve cover and intake valves are clean. Replaced throttle body gasket already, charge pipes are not leaking. Ordered turbo pressure convertor from ebay hopefully that works. Any Idea's?
| All times are GMT -5. The time now is 07:47 AM. |
