Rear right arm covered under warranty?
Have a 07 S, with extended warranty. I was told @ the dealership to replace the rear right arm since it was slightly bent. I wonder if this service is covered by warranty or not.
thx Happy Motoring |
Rear right arm?? Are you talking about the suspension? If so I would assume if you hit something to bend it then it would not be covered under warrantee. However if there is no external damage then I would say that its a manufacturing defect and would be covered under warrantee.
It depends on the warranty ... you'll have to check with the warranty company
Normally they will not cover suspension ... |
Rear right arm issue
Originally Posted by bad venge
(Post 8137)
Normally they will not cover suspension ... May be he's trying to avoid dealership fix it for free??? |
Fairly simple ... Arms bent = Abuse doesn't matter if you or the previous owner did it
If there is no external damage on the part -- scratches--, then it came that way from the factory. Why don't you tell us if there is external damage??
