Running rough
Hi I have a 07 copper S jcw. Lost power and runs rough.
code is 002D7F high pressure fuel injection 1 low side activation. rail pressure is 5 Mpa at idle cyl 1 injection timing 0 cyl 2 injection timing 2.45 cyl 3 injection timing 2.45 cyl 4 injection timing 0 not sure if the low fuel transfer is low or I have an ecu issue. |
| All times are GMT -5. The time now is 07:29 AM. |
