San anyone tell me exactly where the cruise control fuse is?l
I was surprised that the owner's manual doesn't have a cross-reference chart with fuse position number and what that fuse services. Inside the fuse box under the hood, there's not much help there either... mostly similar icons with all different value fuses. Is there a comprehensive online chart that shows the location/job for each and every fuse, including the ones on the driver's side compartment?
Are there any lights that are supposed to go on when the cruise is engaged? I can't seem to get mine going in any gear... but I know its supposed to be 3rd or higher... right? |
There should be a green light that illuminates on the panel then you can hit the + to engage
I've not seen it on the 2nd gens for fuse by fuse layout |
