-   -   Sport mode (https://minicooperforums.com/forum/07-up-mini-cooper-cooper-s-r56-31/sport-mode-4188/)
Lasttoy Mar 18, 2011 09:14 AM
Sport mode
users manual says "push SPORT button, makes car sportier, etc etc---"" but does not tell me what it is doing.. locking auto in 3rd gear? locking torque converter?? advancing timing 4 degrees, etc.. how is auto acting "sportier",,?? has to be doing something to accomplish this "sportier" car.
bad venge Mar 18, 2011 02:06 PM
It changes shift point on the transmission , it basically keeps the revs up so you are more in the power band
mothergoose033 Mar 18, 2011 07:06 PM
From what I was told from the sales person it also tightens up the steering as well as upping the performance. I haven't tried it yet.
bad venge Mar 19, 2011 10:37 AM
I looked in the manual and see no electrical connection to the steering so unsure if they led you astray as some salesmen do ...
mothergoose033 Mar 19, 2011 03:55 PM
I was wondering how it could tighten up the steering since it is so tight to begin with. Maybe he was misinformed or misspoke. On every other matter he was upfront unlike most sales people in the car world. When I get a chance I will put it through the paces and see if I noticed a difference.
bad venge Mar 19, 2011 05:46 PM
Minis use an electrical power steering unit and looking at the schematic all I see is source 12 volts to the power steering unit and the cooling fan both feed off relays/fuses
MindSweeper Apr 13, 2011 11:38 PM
The sport button basically is made to increase driving performance and vehicle handling by changing accelerator pedal ratio (throttle by wire) for quicker response .Also when presessed, initially increases boost pressure on S models.
That is all it does ladies and gentelman....
rusty3096 Apr 16, 2011 04:16 PM
This should help. http://en.wikipedia.org/wiki/Mini_(m...II_.282006-.29
moejcw Apr 17, 2011 09:44 PM
i have a question i have a mini cooper jcw 2010 and i tuned its ecu to 240 hp but i need to tune it more im looking to change it into a twinturbo system where can i find this and will the car handle this much tuning can someone help ?
bad venge Apr 17, 2011 11:12 PM
Alta made the Twurbo that was a turbo WITH the Supercharger on the 1st gen these were over 300hp in factory blocks.
I can't find the twin turbo kit unsure if these were custom
