-   -   Timing problem (https://minicooperforums.com/forum/07-up-mini-cooper-cooper-s-r56-31/timing-problem-12955/)
Mike Burson Sep 7, 2021 09:04 AM
Timing problem
Could anyone help as I'm at a loss.
I've changed timing gear, vanos units and solenoids, vacuum pump, cam sensors, nrv, changed oil and flushed engine. I get code 2845 vanos fault. I've done everything twice with 2 sets of part's. Any help would be appreciated.
Thanks,
Mike
Nzr56coopers Sep 8, 2021 03:52 AM
Hi.
have you cleared the codes as they are stored and not self clearing.
Mike Burson Sep 8, 2021 04:04 AM
Hi, yes each time we clear the codes, the computer says the timing is out of tolerance.
Mike
