-   -   Where is Transmission dip stick (https://minicooperforums.com/forum/07-up-mini-cooper-cooper-s-r56-31/where-transmission-dip-stick-4180/)
calxen61 Mar 16, 2011 08:57 PM
OK, I know there is no dip stick, but how do you:
1. Check trans fluid level?
2. Change trans fluid?
on a 2008 s auto
thanks
cal
bad venge Mar 17, 2011 03:35 PM
According to Mini this is a LIFETIME FLUID.
There are tons of talk on this most do not buy this and there is a filter ect in the tranny
If you do to real oem and punch in the year ect you can get the exploded view and the filter ect
Most Mini dealers will not drain/refill... several DIY types are draining and refilling several times driving several thousand between drains to circulate new/old togetherthen dropping the pan and cleaning the bottom and the filter change then refilling
calxen61 Mar 17, 2011 09:23 PM
Any fluid related failures
Wow, it is hard to find any of that info, how can the fluid last a lifetime. Any failures?
thanks
cal
bad venge Mar 18, 2011 06:47 AM
Yes oddly enough in the 70k 100K range
