08 Clubman Headlamps
Hey guys and gals,
so I have an 08 clubman and I have run into an issue where my high beams won't engage. The low beams work and when I switch the high beams on the icon pops up but the headlamps don't respond. I have checked the fuses and none of them are blown so I'm thinking there is a relay switch somewhere that possibly needs replacing. Has anyone run into this problem, and if so how did you fix it? Cheers!:confused: |
Do you have a bulb out indicator? Sounds silly, but just double check to make sure the bulbs aren't burnt out as it's not uncommon for them to go out in pairs at times.
I do have a bulb out indicator, but I believe that is due to one of my running lights being out. The the bulb for my lights is a low/high combo. No separate bulbs. That is what is stumping me.
