2009 Mini Clubman - Passenger Airbag light and GONG keeps blinking and gonging!
My passenger airbag system/Belt Tensioners indicator lamps keep lighting up on the display, Tachometer, speedometer and the upper indicator warning light. On top of that the GONG sound goes off randomly.
Obviously there is a system failure/Sensor malfunction. I plant to take it in but wanted to see if there was an easy fix or way to to turn the lights and gongs off? thanks |
get it scanned. possible occupancy mat.
09 CLUBMEN Airbag
Yeah, I'm having the same problem, As far as I know the shop is the only way!
| All times are GMT -5. The time now is 07:48 AM. |
