Oil Light
Hi - I did a quick search in the forums, but did not find anything obvious regarding my specific question.
I have a 2012 Clubman that I have owned for almost 2 years. Recently it started acting a little strange - the oil light is coming on after about 15-20min of driving. It flashes on and bings, but then disappears. One time it flashed on, binged, and kept doing this followed by a yellow Check Engine indicator. After stopping and checking the oil (which was fine) it showed no faults and no problems. Now, each time I drive it, the oil light will pop on with a bing, then disappear. The oil level is fine and the engine sounds/runs fine. Any thoughts? It has over 121000 miles on it. |
Check the oil level when car is cold. If level is good, replace the sensor. If the issue continues, replace the pump
