passenger side clbman re barn door will not stay closed
the latch is not stuck closed. the door will not stay shut. any ideas or is there a way to check if its the latch verses something electrical?
thanks |
use a screwdriver and see if it latches and unlatches when you hit the switch. if the latch is all wobbly its probably the lock actuator itself. its probably the actuator.
| All times are GMT -5. The time now is 02:29 AM. |
