02 Mini, low compression #3
Rough idle, stalls and poor acceleration up 3000 RMP. Replace ignition parts and got the same result. Performed a compression test and found #3 cylinder with only 50lbs compaired to the 80lbs to 90lbs the other cylinders gave me. Appears I have a valve or ring problem and I was wondering if this is a common problem with this engine or I just got lucky?
maboston
May 23, 2009 01:55 PM
DriveAwayDreams
7
Jan 25, 2009 11:47 AM
hksir
Feb 1, 2008 04:27 PM
