04 Mini Flat Tire sensor
I had two new tires put on the mini two days ago and now the Flat Tire Monitor is on solid and yellow as soon as you start the car. I checked the tire pressure in all 4 wheels and adjusted them to be the same. I tried reinitalizing the system but that did not help. Thanks in advance for any suggestions.
Tom |
Interesting, I went thru the reinititializing steps and the light is off now.
I'll keep my eye to see if it returns but all is good at the moment...... |
"new" tires have more tread and a different diameter so you have to reinitialize the system you might have to drive a bit to reset it
