2002 Fog Lights, how to turn on
2002: Fog lights all the way at the bottom, and in the spoiler. These aren't the plastic lens ones but are clear and ALL of the way down on the spoiler, lower than the license plate and to the left and right of the metal air screen in the spoiler. There is no fog light switch on the panel by the window & lock switches as the owner's manual says there should be. I have driving lights that have the switch to the left of the steering wheel and they work fine, but I can't figure out how to get the fogs on. Can someone help me?
Thanks, Bob |
if they were factory installed the switch should be the second one from the right ,,, beside the factory passenger window control switch
2002 Fog Lights how to turn on
As Al says, and from memory cars produced after April 1979 require a rear fog light and an internally iluminating way of warning you they are operating.
REAR fog lights were an OPTION in the states ... And they are controlledby the MIDDLE switch on the console
1 Attachment(s)
Originally Posted by kayaklaw
(Post 6825)
Thanks, Bob that been clarify, I do want to know how to turn on this lamps to. thanks |
sound like someone rewired this ... the second switch on right side turns those on ... If that turns on the two on the hood then they rewired it to work that way might have clipped the wires to them ...
