-   -   2002 manual mini is stuck in first gear (https://minicooperforums.com/forum/2002-2006-mini-cooper-r50-11/2002-manual-mini-stuck-first-gear-7826/)
Tyland512 Mar 10, 2015 08:42 PM
So the other day I was driving and when I stopped at a stop sign and put it in 1st gear and tried to go it would get going. So I took it out of 1st gear and put it in neutral and tried again. It still would go. So I tried to put it in neutral and it wouldn't shift into nuetral. It was stuck in first. I looked under the car and there was a puddle of what I think was transmission fluid. It could've been oil but I just fixed an oil leak. And I just put a new clutch in too. So I don't know what wrong. Any idea what could be the problem??? And how much it would cost???
teamslam1 Mar 10, 2015 11:21 PM
It could just be the transmission itself.
slide_auto Jul 9, 2015 09:18 AM
Hello dear
I thing the problem in your transmission with the clutch
Adaptation
Just need to reset adaptation by Mini Cooper pro mechanic
The adaptation 2 steps
One by laptop & 2nd by gear shifter
Good luck
