2002 staring problem
Old Jul 1, 2011 | 10:50 PM
djs's Avatar
djs
Default 2002 staring problem
I have never had a problem starting my 2002 mini. Tonight I went to start it and everything started flashing and clicking but not turning over. Can anyone tell me what this might be?
Old Jul 2, 2011 | 08:20 AM
bad battery did you try to jump it ?
Old Jul 2, 2011 | 08:30 AM
djs's Avatar
djs
no it was at midnight last nite so I will try that today
Old Jul 2, 2011 | 05:52 PM
djs's Avatar
djs
Ok so I cleaned the battery terminals and jump started it. It started right away and five minutes later also. Then I tried several hours later and it won't start again. Does that sound like the battery? If not what is my next step?
Old Jul 3, 2011 | 01:10 PM
chiquito's Avatar
Default Battery
Is got to be the battery. Take your battery to the shop and recharge it. If it doesn't hold a charge you will be needing a new battery.
Also test the alternator. While the engine is still running remove the ground cable(black) from the battery. If the engine shuts off you have a faulty alternator.
Old Jul 3, 2011 | 03:34 PM
DO NOT do that test on any MINI !!!!
Take it to Autozone ect and have the charging system and battery tested for FREE
ccraw2219
Feb 25, 2014 12:54 PM
zaat61
Jan 25, 2007 12:47 PM
