2004 Mini Cooper oxygen sensor
I received the following fault code:
P0130 O2 Sensor Fault (Bank 1 Sensor 1) If I am correct it should be the pre-cat sensor; however, I do not know where this sensor is located. Could someone post a picture or video showing it? Also my car has two oxygen sensors, correct? |
The sensor is located just above the cat and right after the exhaust manifold where it comes out of the engine. Not real easy to get to. I just changed one there. You have to do it from under the car.
