2006 Cooper 250,000 miles!!
I'm looking at a 2006 Cooper, W10 engine with a LOT of miles. However, in the last two years, they have updated:
Clutch
Battery
Shocks
Struts/mounts
engine mounts
gearbox mount
Rear-end seal
Tires
Interiour looks surprisingly descent. No seat cracks. A/C works (important for TX). Some rust dots on the hood. A small dent on the fender. No leaks.
Anything I should consider on this? I'm a BMW guy. However, I dont want this to be a high maintenance vehicle. Its for a kid to go to and from school with.
I'd like to know if there is anything I shoudl specifically look for, etc.
Love to hear your feedback.
Clutch
Battery
Shocks
Struts/mounts
engine mounts
gearbox mount
Rear-end seal
Tires
That Tritec engine has been nicknamed “the unbreakable lump”. As long as the oil changes were done regularly, it should be fine. I’d take it to a mechanic for a compression test to be sure.
The manual transmission is far more reliable than the CVT one. There was a 5 speed and a 6 speed Getrag, and a 5 speed Midlands. The Midlands is said to be marginal. The 5 speed Getrag seems to be second best as far as reliability, and the 6 speed is excellent.
Hope this helps.
P.S. I use Loctite Extend on the rust, then touch up paint.
Hope this helps.
