-   -   abs, asc, flat tire, monitor, brake pad lights on (https://minicooperforums.com/forum/2002-2006-mini-cooper-r50-11/abs-asc-flat-tire-monitor-brake-pad-lights-9205/)
donmack Jul 10, 2016 03:36 PM
2004 cooper, replaced left strut mount and both front control arms bushings (which are on the rear of the control arm) alined toe in/out to 0'0". removed and cut the wire to the brake pad sensor, (left front and rear right) tied brake pad wires together. pulled the car of the lift and now i have abs, asc, brake pad, flat tire monitor lights all on. what the heck, i didnt do any thing with the braking system, tire presure. the dsc switch wont turn off the asc light. check all the wire cant find any bad wiring. any ideas on what to do next?
