AC/Heater Blower Not Working
Hi, I have a 2006 Mini-cooper and at one point I tried turning on my AC but no air comes out. I put it to either 1, 2, 3, or 4 to see if any air would come out but nothing. AC led button would not turn on either.
It seems that the blower stopped working for my AC/Heater. Even regular vent air would not work. It had worked a couple of times where I left it on at level 4 and it suddenly started blowing cold air. I checked the fuse that is located under the steering wheel and the fuse for the blower seems to be good. I even replaced it with the spare and it worked one time when I took the mini for a drive. But now it is dead again. Any ideas on what to look for? Your help is greatly appreciated. Thx. |
2006 mini cooper convertible i am having the same issue
? did you ever solve this issue? |
i also have the same issue
Did anyone get an answer to this. The mini garage is saying a replacement fan at around £400 including labour because they've got to take the dash out.
Originally Posted by John Dean
(Post 22956)
Thanks for the link. The garage finally came back and accepted the fix under warranty - which is great because the DIY sounded a nightmare - dashboard out.
