-   -   fog/rally light installation (https://minicooperforums.com/forum/2002-2006-mini-cooper-r50-11/fog-rally-light-installation-3690/)
kimmer Nov 5, 2010 11:46 AM
has anyone installed aftermarket fog lights up near the grill/bumper. looking for suggestions for mounting points and would appreciate any input by those who have done it-thank you!
bad venge Nov 5, 2010 06:21 PM
http://www.outmotoring.com/mini-coop..._brackets.html
These mount on the hood
kimmer Nov 6, 2010 08:24 AM
thank you for the link , I will give those a try-
kimmer Jan 10, 2012 09:49 AM
Installing PIAA 5430 light kit to Xenon headlights
Does anyone have experience installing the PIAA 5430 driving lights on a xenon equipped Mini? I previously had these lights on my 02 MINI w/ halogens and had no problems with wiring them up. In trying to install on the 05 with Xenon lights, several of the wires in the headlight harness show voltage when the high beams are on. I have seen other posts which recommend wiring to the yellow/green wire on driver's side. However, my install is going on the passenger side and there is no yellow/green wire. I tried using the yellow/blue wire but that resulted in the PIAA lights being on whenever the headlights are on. I would like to have it wired so that the PIAA lights come on only when the high beams are on. Does anyone know which wire feeds the high beams on the passenger side? I hate to just indiscriminately start hacking away at the wires in the harness! Appreciate the help!
