Getrag 6spd swap issue/queestion
Hello,
I am in the process of swapping an R53 6 spd Geartag into my R50, So far the process has been pretty smooth but I have came across an issue and I can't find anyone else posting about it. I mated the 6spd with the engine, attached the shifter cables (from another R53) and when I raised the transmission up to mount it, the shifter cables are very close to the AC line going under the battery holder bracket. In fact, once the tramissions is raised, I am unable to shift the gear into 2,4,6 or reverse because there is not enough clearance for the shifter. Has anyone ran into this? I am at loss here. Any help would be appreciated. Pictures below show the issue https://cimg5.ibsrv.net/gimg/minicoo...c61c3b46e3.jpg https://cimg6.ibsrv.net/gimg/minicoo...d50c44908c.jpg |
Turns out after bolting everything down, there is just enough space for the sifter cables to go through into every gear.
| All times are GMT -5. The time now is 06:03 AM. |
