-   -   Head gasket/timing chain (https://minicooperforums.com/forum/2002-2006-mini-cooper-r50-11/head-gasket-timing-chain-6063/)
minibob6 Mar 7, 2013 05:07 AM
I have '06 mini base model. Need to replace head gasket. ( Actually need to replace a few burned valves due to heavy carbon build up ). Besides gasket set, new head bolts and new camshaft sprocket bolt, is there anything else I will need? Also, how do I re-time cam and timing chain when putting back together? Any advise or suggestions would be great. ANy only have any idea how long a job this is?
bad venge Mar 7, 2013 09:06 PM
BUY a service manual it will give you the needed specifics on torque/ alignment ect
It's far too involved to post all needed info here.
We did one in a weekend ,
minibob6 Mar 10, 2013 06:49 AM
head gasket/timing chain
Thanks for the advise. Just ordered a Haynes guide I'm sure it will be well worth the $25 investiment. I saw photos on line where some one
removed timing chain sprocket and kept tension on it upward with head off to avoid having to re-time. Any one able to do this successfully, any
ideas of how to get head off while keeping it pulled up ward would be great
bad venge Mar 10, 2013 02:02 PM
I've seen guys look it down on the inside of the head one guy made a rig that bolted to the valve cover holes and came out and engaged the sproket
kyled Mar 13, 2013 07:40 PM
i know alot of modern cars are going to better timing chains, and i was wondering when i should start worrying about it on my mini
bad venge Mar 14, 2013 08:11 PM
I've heard 100k and or making noise
03Mini Mar 16, 2013 10:22 PM
^^^ What's the noise sound like? Where and when does it make noise? I have one making a strange noise under acceleration. Doesn't happen 100% of the time but it has me concerned.
