I can shift gears without engaging the clutch
How old is the clutch and has it ever been replaced? Can you get it into any other gear? What is your pedal travel like? Does the clutch pedal feel spongy at all? Was there any slippage of gears? Any hydraulic leaks under the vehicle? If you've determined it is in fact the clutch we have some pretty awesome kits below as well as a DIY that can help with the replacement:
Clutch kits: http://www.pelicanparts.com/catalog/..._pg1.htm#item0
DIY: http://www.pelicanparts.com/techarti...eplacement.htm
shelbyrg1
Dec 2, 2016 09:55 PM
Sep 23, 2015 04:11 PM
Feb 25, 2015 10:07 AM
