Indicators not working
When I press the hazard button or the indicator stalk the dash board shows the indicator lights are on but non of the lights outside the car work.
I've checked: the bulbs (they are fine) fuses (they are fine) ohms to bulbs (they are fine) changed the indicator stalk (same problem) I am just confused anyone had this issue or know how to fix it? cheers |
Hi Jamies, I understand it has been over 4 years since you posted this but I am currently having the exact same issue with my 2004 R50! All of my turn signal indicator lights are not working, but the hazards / indicator stalk shows the lights are on. Other exterior lights are fine.
I was wondering if you found a solution to this at the time? Did you work out what the problem was? If so would you be able to share? Any information would be very valuable. Thanks! |
| All times are GMT -5. The time now is 03:06 AM. |
