Installing DRL on ACC
Old Aug 5, 2018 | 06:51 AM
johansef's Avatar
Default Installing DRL on ACC
I like to install an aftermarket DRL set. I bought a controller for them. In order for them to function properly, I have to connected 1 wire to the 12V ACC.
I connected them to the 86 pin of the aircon relais in the fuse box under the hood. On ignition off, the lights stayed off as intended. On ignition on the switch on, also as intended. But when turning the ignition off again, the lights stayed on. Any thoughts on how to solve this or a beter way to connect the DRL controller?
Minimaker
Aug 20, 2017 03:22 AM
Yuris
Mar 21, 2017 02:31 PM
kimmer
Jan 10, 2012 09:49 AM
ZoomMini
Jun 7, 2010 07:13 PM
Coopermini
Oct 14, 2007 07:32 PM
