Instrument Panel lights won't turn off
Old 09-06-2011, 09:00 PM
jmarcus's Avatar
Default Instrument Panel lights won't turn off
Hi,
A rainy day here in Boston. When I got home and shut off the car the instrument panel wouldn't turn off. I noticed when I open the door, it bings as if reminding me to turn off the lights or that I have left the key in the ignition. I started the car again and drove it around the block, nothing changed. I turned the lights on and off, and I flipped most of the switches.
Any thoughts short of disconnecting the battery?
I have a 2003 Cooper S
James
Old 09-07-2011, 05:49 PM
check the relay that controls the lights might have fused or a bad light switch
Old 03-24-2018, 09:30 AM
Michele Marongiu's Avatar
Default Some Problem
Hi, have you solved in any way?
I have the same problem!
Old 03-24-2018, 09:38 AM
Old 03-03-2022, 06:40 AM
Scoobyfan's Avatar
Default Mousture
Originally Posted by jmarcus
Hi,
James
make sure your fuse box is dry and check wire for corrosion. Ya probably way late on this answer. Sunroof drains like to spring leaks and ofcoarse they run inside the car and straight down to the electrical.
Old 03-22-2022, 08:46 PM
minicooper56's Avatar
i have one more issue then this my head lights and high beams wont work and the parking and indicator light wont turn off any suggestions all i have been able to disconnect the battery
Old 03-23-2022, 06:39 AM
Scoobyfan's Avatar
check the back of your fuse panel for corrosion,check relays for the headlights and possibly your headlight switch.. cant say for sure if its any of these but its what comes to mind at the moment. I dont know all to mutch about the headlight setup on these minis its different from what im use to but if i have any other ideas ill jot them down.
Mini JJ
11-07-2020 02:06 PM
scienceesl
08-24-2015 11:37 AM
Budroe
10-30-2014 09:49 AM
BlackCatGuy
09-10-2011 05:31 PM
halpernjs
12-23-2008 08:09 PM
Quick Reply: Instrument Panel lights won't turn off
