Instrument Panel lights won't turn off
Hi,
A rainy day here in Boston. When I got home and shut off the car the instrument panel wouldn't turn off. I noticed when I open the door, it bings as if reminding me to turn off the lights or that I have left the key in the ignition. I started the car again and drove it around the block, nothing changed. I turned the lights on and off, and I flipped most of the switches. Any thoughts short of disconnecting the battery? I have a 2003 Cooper S James |
check the relay that controls the lights might have fused or a bad light switch
Some Problem
Hi, have you solved in any way?
I have the same problem! :( |
Some Problem
Mousture
Originally Posted by jmarcus
(Post 12934)
Hi,
i have one more issue then this my head lights and high beams wont work and the parking and indicator light wont turn off any suggestions all i have been able to disconnect the battery
Originally Posted by minicooper56
(Post 29282)
