My 05 Mini problem's
Old May 22, 2019 | 08:54 AM
harley95's Avatar
Default My 05 Mini problem's
Hi guy's my 05 mini is running a little rough it seem's like one of the cyl's is not firing all the time, i have changed he spark plug's the dash light for Deterioration in exhaust emission values has started to flash on and off The A.B.S. light is on but the disc's are showing sign's of wear so should that light be on because of the wear or do i have another problem ? Thank's for any help.
Old May 24, 2019 | 12:40 PM
tedpet's Avatar
if one of the cylanders is not firing, you will have a check engine lite. the code will show a misfire when you attach a scanner to the ODBC port.
What code do you get?
guysnydr
Mar 2, 2019 05:05 PM
Tim Hines
Nov 9, 2016 11:49 AM
Polarice
10
Mar 6, 2012 08:14 AM
JimMigliaccio
Oct 11, 2011 08:36 PM
