-   -   Over Heating! Please help! (https://minicooperforums.com/forum/2002-2006-mini-cooper-r50-11/over-heating-please-help-3706/)
Texas_Mini Nov 11, 2010 10:42 PM
My mom has been having issues with her car getting hot! I checked the fluids in the over flow it was bone dry so I add some to the max line. Its still getting hot. She can drive about 5 - 7 blocks and turn the car off and the fan will kick in like it is over heating. I am good with cars but cant figure out why it only gets hot when sitting still. Once she gets moving the temps come down and the car seems to be fine!
Additonal note: The trunk/hood light comes on when I unlock and open the door. It comes on for 5 seconds and goes off!
Texas_Mini Nov 12, 2010 07:03 PM
Bump!
Any one on here had the same situation, she doesnt have the funds to take it to the dealership or an indy mechanics so I need to fix this myself!? Might some one have a manual or any kind of help!
Thanks a million in advance!
bad venge Nov 12, 2010 08:15 PM
It's a normal cooling system... Check the easy stuff first , thermostat and radiator cap
Also check for leaks ... You might have a bad hose/clamp . Did you check the Oil for signs of coolant ?
Texas_Mini Nov 14, 2010 02:38 PM
Do they have electrical thermostats? I was told they might by a local inspection shop.
bad venge Nov 14, 2010 06:20 PM
http://www.penskeparts.com/DiagramsM...4&rnd=06222010
http://www.penskeparts.com/DiagramsM...png?v=06222010
scrill down shows standard thermostat
there is an electronic thermost to turn on the fans
Sblumenthal Sep 18, 2011 08:51 AM
Running hot
Hi. I'm having a similar issue--temp gauge is on high and fan runs after i turn off the car. I was very low on coolant and put more in. Unfortunately, that did not correct the problem. Is there any simple fix. Will it hurt the car if i drive it to my mechanic, approximately 20 miles away?
Thanks for your help!:mad
