problems with fan draining battery
Old Feb 3, 2013 | 02:57 PM
mturco's Avatar
Default problems with fan draining battery
I have a 2003 Mini and lately at times a fan is staying on after the engine is turned off and draining my battery. Because it doesn't always do this, the mechanic can't figure out what is happening. Does anyone else have a common problem?
Old Feb 5, 2013 | 03:07 PM
there are only a few causes ,
car overheating ? low on coolant bad stat ect may cause the fan to run after trying to cool it off
bad relay , bad connections on harness , bad thermostat switch
I've seen the relays stick intermittantly
I've seen the connectors get corroded
Jun 5, 2013 01:46 PM
12dja
Nov 7, 2012 07:14 PM
Shirl_inLA
Nov 30, 2011 03:55 PM
Riddla
Oct 5, 2008 01:39 PM
sang337
Jul 11, 2005 12:46 PM
