Question about 2003 Mini Cooper
There is a toggle switch between the driver's side window switch and the lock/unlock switch that's labeled "DSC." What does this switch do? Also, there's a button beneath my e-brake that looks like the "low tire pressure" indicator in most of your modern Jeeps and other vehicles with tire pressure sensors. What is the function of this button?
Thanks, Wes |
RE: Question about 2003 Mini Cooper
DSC is dynamic stablity control. If you hit the switch it turns it off otherwise normally it's always on. Read the manual to learn what it does. It's pretty much to help your driving. The tire monitor will monitor the pressure in your tires for any changes. When it changes it will flash, you don't need to hit the button unless something is wrong or your change the pressure. Read the manual, you'll be fine then.
