R50 Radiator Fan Comes On 5 sec After Starting
I have a 2003 Mini Cooper R50. I just replaced the transmission and I noticed the radiator fan comes on high about 5 seconds after the car is started...cold or hot. Fan goes off when I turn key off. The AC and Defroster are off. I can read the temperature sensor from my scan tool and it is reading correctly. Temp goes up as engine warms. coolant level is ok I reset the ECU (Test 19 -21 Reset) and it still comes on. Is there some other temp sensor that I’m missing? Thanks |
| All times are GMT -5. The time now is 10:10 AM. |
