-   -   R50 Radiator Fan Comes On 5 sec After Starting (https://minicooperforums.com/forum/2002-2006-mini-cooper-r50-11/r50-radiator-fan-comes-5-sec-after-starting-10741/)
Djkslt Jan 30, 2018 04:01 PM
I have a 2003 Mini Cooper R50. I just replaced the transmission and I noticed the radiator fan comes on high about 5 seconds after the car is started...cold or hot. Fan goes off when I turn key off.
The AC and Defroster are off.
I can read the temperature sensor from my scan tool and it is reading correctly. Temp goes up as engine warms.
coolant level is ok
I reset the ECU (Test 19 -21 Reset) and it still comes on.
Is there some other temp sensor that I’m missing?
