Radiator fan keeps running
Old Aug 6, 2007 | 01:10 PM
zosim's Avatar
Default Radiator fan keeps running
Hi,
Sorry if this has already been posted before. I did a search but did not find it.
Wehave a 2004 Mini Cooper. Recently, we noticed that the radiator fan continues to run for a few minutes even after the vehicle has been shut off. I checked and found my coolant to be below the minimum line. So I added more fluid as maybe that was the one causing it. Nope, this morning it was still doing it.
Anyone had any similar experience?
Thanks.
Old Jan 1, 2008 | 07:39 PM
nebula7's Avatar
Default RE: Radiator fan keeps running
YES!!!!!!!! I had the same experience! The MINI has a problem with the thormostat assembly. They leak slowly until you overheat. That happened to me. Take it to the dealership.
Do you hear a fluid "swishing" sound coming from behind the glove box? If you do it means your level is low and there is air in the system.
Fix it right away. You will overheat.
Dan
itswrongway
Oct 3, 2014 05:42 PM
itswrongway
Oct 3, 2014 05:13 PM
Jun 5, 2013 01:46 PM
dens_cooper
Dec 8, 2009 08:51 PM
jetblackmini_dubai
Mar 4, 2009 10:11 PM
