Replacement Oil Filter Housing Drainback Valve
Old 10-12-2018, 02:46 PM
tanstin's Avatar
Default Replacement Oil Filter Housing Drainback Valve
Hey guys! I've been working on replacement oil filter pressure relieve valves lately, and they are now stocked and ready to sell!
The black valve inside the oil filter housing often becomes brittle during oil changes, then breaks when the filter is being put in. There is no aftermarket support for it, nor OEM, or there hasn't been anyways. I now am supplying Nylon replacements through OutMotoring.
I have personally been running it in my car, in Arizona heat and brutality, for close to 2,000 miles and have not had an issue. The factor of safety is closely related to how aerospace is rated, which is much superior than the automotive FoS.
If you are in need, it is much easier to replace than the complete oil filter housing. Thanks!
If you have any questions, do not hesitate to ask!
-Tanner
https://www.outmotoring.com/oil-filt...rep_12345.html
Old 04-10-2022, 08:49 PM
bkidd73's Avatar
Hi there - are you still making these replacement valves for R53s?
Old 06-22-2023, 07:28 PM
Lwhcchh's Avatar
Default Oil filter housing return
As I understand it, this replacement valve will NOT work in an R50 hatchback automatic base car. Is that correct?
Old 06-27-2023, 02:45 PM
Platinum Sponsor
Visionary44
01-17-2019 02:34 PM
10-30-2014 09:32 AM
supanatral
01-10-2012 02:55 PM
MORGAN
02-07-2010 06:54 PM
jball
12-02-2009 04:15 AM
Quick Reply: Replacement Oil Filter Housing Drainback Valve
