-   -   Replacement window regulator that lasts more than 2 years? (https://minicooperforums.com/forum/2002-2006-mini-cooper-r50-11/replacement-window-regulator-lasts-more-than-2-years-13008/)
Kara Oct 11, 2021 09:15 AM
Does this exist?
I've used only genuine mini parts so far and all 3 replacements between the 2 doors have failed after 2 years.
Has anyone converted to manual window cranks? Lol
Nzr56coopers Oct 12, 2021 03:59 AM
If they are failing on a regular basis,it would point to a power overload from an electrical fault,rather than part failure.have yo had the car charging system checked,carried out or has the car had modified electrical systems.seems strange to have then fail
Kara Oct 12, 2021 06:59 PM
No no, they physically FALL APART lol. It is not an electrical issue.
Nzr56coopers Oct 13, 2021 12:35 AM
Falling apart,are you buying cheap parts,as they should not fall apart on a regular basis.
Kara Oct 13, 2021 07:55 AM
Only genuine mini parts
