-   -   water in cabin (https://minicooperforums.com/forum/2002-2006-mini-cooper-r50-11/water-cabin-12884/)
ChrisB Jul 22, 2021 07:58 AM
water in cabin
2004 Mini, rainfall, I think, is seeping into the floor of the driver's side of the cabin. Sucked out almost 4 gallons after a rain storm. And it's still coming in! Can't understand from where. Exasperating. Anyone out there able to help this hapless owner? Tx!........chris
Nzr56coopers Jul 24, 2021 01:49 AM
Sorry for the damage,they have an issue with the door seal rubber,remove the black rubber easy job,fill the channel that fits to the car with bathroom sealant,replace the door seal rubber on the door frame,clean off any access sealant the comes out.job done,it packs out the seal to stop moisture ingress,make sure you remove all the water from the carpet,leave the windows open to avoid smelly car syndrome
Dbnoaol Aug 12, 2021 07:20 AM
check the drains for the sunroof in it has a sunroof. They are likely clogged with debris..
