Whining noise while decelerating on gear or neutral
Hey Guys,
I have a 2002 mini cooper and so far it didn't give me any problem. 91k miles. Out of sudden, while changing gear at a stop, it made some noise before inserting the gear and from then it has been making a loud whining noise only when I decelerate. It doesn't matter which gear I am on or if neutral, the noise remains, but it happens only when decelerating. Could you help me identifying the problem? Thanks a lot for your help. |
91k miles
Clutch kit need to replac
Release bearing Release bearing guide Clutch fraction plate Clutch Prussure plate Good luck |
| All times are GMT -5. The time now is 03:29 AM. |
