-   -   05 Mini S problems. (https://minicooperforums.com/forum/2002-2006-mini-cooper-s-r53-12/05-mini-s-problems-4390/)
baileelucas May 8, 2011 07:28 PM
05 Mini S problems.
So recently, my 2005 mini s (manual) has been just cutting off randomly when in neutral. Also when I cut my car off, my fan keeps running for a few minutes. And then today I was just driving and my engine temperature gauge went all the way up and then went right back down to normal. There are just a lot of weird things happening and I was wondering if anyone has any ideas on what could be happening to it. Thanks! :)
cerroneseuropean May 11, 2011 08:17 PM
Your fan Running issue could be a problem with low coolant chk coolant level when cold. they have a very common coolant leak @ plastic thermostat housing to cylinder head they leak coolant (very common)
Good luck
deathblosom May 18, 2011 09:32 PM
The temp gauge showing getting hot then going cooler quickly could be the sign of a sticcky thermostat. An easy fix, but not sure how easy on a mini.
