-   -   06 Mini Cooper s problems help (https://minicooperforums.com/forum/2002-2006-mini-cooper-s-r53-12/06-mini-cooper-s-problems-help-11153/)
Mini_Garage Jul 9, 2018 11:52 AM
So Monday my mini was running great, pulled into the gas station (didn’t get gas) and started to leave. Car started up fine but As I pulled away from the pump my car started to misfire. I pulled it aside and ran codes. Pulled the code for limp mode and a misfire in cylinder three. I assumed maybe a spark plug so I swapped 3 to 4. Cleared codes and started the car again. With my luck, it started misfiring again. I ran code and it came up with p0300 (random multiple cylinder misfire) and p0313 (misfire with low fuel detected). So I’m the parking lot I replaced plugs, coil pack, incectors, and fuel rail. Yet gain, no luck. Any ideas? Anything helps. Motor cranks over while throttling gas, it has a really hard start, and it just stumbles the whole time running. I drive it home two blocks and it ran like crap the whole time.
SuPeR-aNi Aug 6, 2018 01:50 AM
Check fuel pressure? Perhaps a clogged filter/pump going out?
Mini_Garage Aug 6, 2018 06:38 AM
Problem found! It was a broken valve spring....
Bobby Briggs Oct 12, 2020 06:45 AM
Wow! Never would have suspected that! good catch~
