-   -   2002 cooper overheating (https://minicooperforums.com/forum/2002-2006-mini-cooper-s-r53-12/2002-cooper-overheating-3932/)
sdr13 Jan 8, 2011 03:08 PM
my 2002 mini cooper s has begun overheating in the past few months. my mechanic can't find any leaks in the coolant but when I get it back within a week I have the same problem- it overheats and sometimes makes a banging noise that feels like it is coming from by the driver side of the engine. Has anyone experienced this problem, I am very worried and my mechanic seems clueless. help! :confused:
bad venge Jan 8, 2011 04:25 PM
is it loosing coolant ?
What has been done by the mechanic ?
What has been replaced ?
terrysil Mar 3, 2011 10:59 PM
cooling problem
any leaks? if not is your fan cycling on when it is supposed to, i believe it activates the low setting at about 205 degrees F, and the high setting at 220 degrees F.
if the above are ok, is your coolant low? if so check to see if you have water in your oil pan. After letting the car sit overnight, Just barely break loose the oil pan bolt and if water comes out you have a serious problem, could be blown head gasket, could be cracked block
indiandrives9999 Mar 30, 2011 12:04 AM
I think u need a good mechanic.
Massenitti701 Apr 13, 2011 11:07 AM
Originally Posted by sdr13 (Post 10707)
my 2002 mini cooper s has begun overheating in the past few months. my mechanic can't find any leaks in the coolant but when I get it back within a week I have the same problem- it overheats and sometimes makes a banging noise that feels like it is coming from by the driver aftermarket parts side of the engine. Has anyone experienced this problem, I am very worried and my mechanic seems clueless. help! :confused:
You need to find a better mechanic lol.
