2004 Mini Cooper S: ABS/Brake Pad Sensor Connectors
I purchased a 2004 Mini Cooper S and knew there was some work to be done on the vehicle. I have started tackling some of those items and am now dealing with the lights on the dash. The following lights are illuminated: ABS, brake pad wear sensor, and tire pressure.
I changed the brakes on the car and went to replace the brake pad wear sensor (driver front) and it was then that I found the car had been wrecked and the front bumper replaced. Apparently the original bumper was damaged in the wreck and during that time, the plugs that the ABS and brake pad wear sensor connects to have been ripped from the car side harness. Does anyone know what the part numbers are for these, where I can find these parts, or any other details? I have been looking for sometime and cannot determine how to fix this. |
You'll want to look here: RealOEM.com - Online BMW Parts Catalog.
Not sure if you can get those by themselves or if it's a whole harness that will be needed. Good luck. |
Go over to North American motoring website, go into their marketplace, there are many R53's being parted out. Tell them what you want and how long the wiring attached to the plug needs to be, doubt you even want the entire harness, this is much simpler - get it, splice it in and call it a day!
If you don't know how to do this find another local mini owner that has some mechanical ability and ask, offer beer, dinner, etc. If you lived near me I could easily do this. Good luck BruceJ |
