-   -   Better interior door handles? (https://minicooperforums.com/forum/2002-2006-mini-cooper-s-r53-12/better-interior-door-handles-252/)
TheBishop Oct 21, 2006 02:47 AM
Does anyone know where to get metal interior door handles? anything better than the chinsy plastic ones?
miniwa Nov 30, 2006 12:53 PM
RE: Better interior door handles?
I'll say! It was cold out and pulled the inside door handle to get out of the car and something broke inside. Now the handle doesn't snap back and you have to hit the unlock switch to get the friken door open. Now I have to figure out the problem...cause the wife said it's my fault[:@]
shmoovio Dec 8, 2006 01:42 AM
My door handle on the passanger side broke the same way. It is the double pull action that tricks people. They pull it once and don't let go until they break it. I took it to the dealer and they said that it is a cable that is connected with some sort of T-shaped end that can pop out of place. The dealers have a clamp that goes on to it and fixes the problem. Had them do both doors (just in case) and have had no problems since.
Adam Dec 10, 2006 08:38 PM
ORIGINAL: shmoovio
Yeah, I've almost had to murder a couple of people that have almost ripped mine off. What the hell are people thinking?.. if it doesn't open with slight pressure, ripping the handle off the door isn't going to do any good either.
PS. You can get the double pull thing deactivated at the dealer.
Chuck Taylor May 25, 2008 04:58 PM
ORIGINAL: shmoovio
Just had the driver's side door cable fixed. Had to open the door rolling the window down and opening from the outside. Was told that this is a common problem.
