Clutch Issues
Hello, I have an 06, I am sure this gets asked quite frequently, but have to ask. Just recently while driving, the clutch just quit working, no prior slipping issues, was getting difficult yo shift once in a while. So I replaced the slave, still no dice, I tried every way I could to bleed, except using pressure bleeder, the last time this happened I just let it sit over night and it worked, this time nothing. I get a good pedal when this piston is clamped in, but once I release the clap to install I loose half of the pedal and it doesnt look like the rod extends far enough to disengage the clutch. I also replaced the master cylinder just in case that was the issue.
Looking for any other ideas or am I going to have to purchase a pressure bleeder. Thanks. |
