Drivers door handle
Old Oct 13, 2014 | 11:24 AM
nhusa's Avatar
Default Drivers door handle
HI guys,
I got my a daughter a 2004 Mini S and am having a problem with the inside driver's side handle. It will not open the door! I took the panel off and found that the handle and cable were OK but the end near the latch was disconnected. It had a swaged on loop but I could not figure out where it attached. Can someone provide a picture or description?
Old Oct 30, 2014 | 09:44 AM
Here is some info and pictures, this is for Gen 1 MINI R50 R52 R53 models, You Have and R53 Cooper S 2004 year :
Here is the door diagram for the Gen 1 MINI R50 R52 R53.
#1 in the diagram
Door Lock Unit - Left ( Driver Side )
http://www.ecstuning.com/Search/SiteSearch/51200556768/
Door Lock Unit - Right ( Passenger Side )
http://www.ecstuning.com/Search/SiteSearch/51200556769/
Also.
On the inside handle there is a cable , check the cable connection first.
Here is # 10 in the diagram that is the cable. Set between the lock and handle.
http://www.ecstuning.com/Search/SiteSearch/51217143538/
Then on the outside Handle:
In the picture item #1 is the handle which has a connection cable to it. which links down to the lock.
Door Handle Chrome - Right ( passenger side )
http://www.ecstuning.com/Search/SiteSearch/51217198472/
Door Handle Chrome - Left ( Driver )
http://www.ecstuning.com/Search/SiteSearch/51217198471/ES90104/
Thanks and let me know what you find.
tkendall
Jun 18, 2013 09:01 AM
revy_ajax
Jul 30, 2012 11:43 AM
NiuNiu
Jun 6, 2011 04:09 AM
donaldb
Jan 17, 2009 09:04 AM
Sharkfyn
May 20, 2008 03:58 PM
