Drivers door handle
HI guys,
I got my a daughter a 2004 Mini S and am having a problem with the inside driver's side handle. It will not open the door! I took the panel off and found that the handle and cable were OK but the end near the latch was disconnected. It had a swaged on loop but I could not figure out where it attached. Can someone provide a picture or description? |
Here is some info and pictures, this is for Gen 1 MINI R50 R52 R53 models, You Have and R53 Cooper S 2004 year :
Here is the door diagram for the Gen 1 MINI R50 R52 R53. http://www.realoem.com/bmw/diagrams/t/a/215.png #1 in the diagram Door Lock Unit - Left ( Driver Side ) http://www.ecstuning.com/Search/SiteSearch/51200556768/ http://c1552172.r72.cf0.rackcdn.com/87746_x600.jpg & Door Lock Unit - Right ( Passenger Side ) http://www.ecstuning.com/Search/SiteSearch/51200556769/ http://c1552172.r72.cf0.rackcdn.com/85138_x600.jpg Also. On the inside handle there is a cable , check the cable connection first. Here is # 10 in the diagram that is the cable. Set between the lock and handle. http://www.ecstuning.com/Search/SiteSearch/51217143538/ http://c1552172.r72.cf0.rackcdn.com/94860_x600.jpg Then on the outside Handle: In the picture item #1 is the handle which has a connection cable to it. which links down to the lock. http://www.realoem.com/bmw/diagrams/t/a/216.png Door Handle Chrome - Right ( passenger side ) http://www.ecstuning.com/Search/SiteSearch/51217198472/ http://c1552172.r72.cf0.rackcdn.com/417650_x600.jpg & Door Handle Chrome - Left ( Driver ) http://www.ecstuning.com/Search/SiteSearch/51217198471/ES90104/ http://c1552172.r72.cf0.rackcdn.com/420705_x600.jpg Thanks and let me know what you find. |
| All times are GMT -5. The time now is 04:55 AM. |
