Error Codes: P1238, P0113, P0108, 5E16 & 5E19
(Update 13/06/2025)
Solved the issue by replacing ECU with secondhand one and being cloned by Autotronics. (UPDATE 13/02024) Replaced Map Sensor + tried the original Replaced T-Map Sensor X 2 + tried the original Replaced Main Engine Wire Harness Still not fixed the issue. I am seeing the following codes: P0108 - Absolute pressure intake manifold-barometric pressure-input high P1238 - Pressure sensor intake manifold before compressor input high P0113 - intake air temperature high 5E16 - CAN connection to instrument cluster 5E19 - CAN data fault from DME / DDE These codes weren't originally presented but basically my radiator blew out. I fitted a new one and this has since appeared.I did take supercharger off but was only checking I put a seal on from the other week when I did the service / water pump which was fine.The grey vaccume hose to map sensor was broken but I replaced it. I have removed and refitted a couple of times to ensure it's sorted correctly. https://cimg8.ibsrv.net/gimg/minicoo...85cb89b4c7.jpg |
Error codes P0108 and 5E19
Hi, I’m having a similar issue with a R53, did you have any luck solving the problem? I’ve replaced both MAP and TMAP sensors but P0108 in the DME and the 5E19 keep coming back
Originally Posted by AlbertMell
(Post 31121)
Hi Albert, I did my ECU lost it's ground, got second hand one and sent off to Autotronics and that has since solved it. |
| All times are GMT -5. The time now is 09:17 AM. |
