Headlight Only Works When Highbeams On
Old May 29, 2024 | 03:58 PM
Kyra's Avatar
Default Headlight Only Works When Highbeams On
Hello! I have an '02 S with xenons. Over the winter the bulb burned out or whatever xenon bulbs do either way it stopped working and I needed to replace it. I replaced both bulbs safely and at first everything was fine. Then at some point the driver side would no longer turn on unless you flicked the Highbeams on then off. Now it has evolved to the point where it will only turn on if the HighBeams are on fully. I checked the relays they're fine, I checked the lil silver box on the headlight it's fine, I checked the bulb itself it's fine. I've run out of options aside from tracing wiring which I don't wanna do unless necessary it seems tedious or replacing the light entirely. So before I do that I wanted to know if someone here has ever encountered this rather stupid problem before. Thanks!
kelly'smini
Jun 14, 2017 08:14 PM
kerwinq
Nov 29, 2016 11:49 AM
Aug 22, 2013 07:00 PM
davidjbsb
Jun 11, 2013 01:58 PM
Spanky
Jan 25, 2009 07:55 AM
