HELP!…please 🙏🏼 coolant leak 😵💫
Hello All,
I’ve seen this problem across several forums but no answers so I’m seeking help or comments from fellow mini owners. the Mini drives great when I put coolant before I drive it and it will usually last 30-45 minutes before it’s empty again. During this time the car does not overheat or change in drive ability. Below are some specs PLEASE take a read the rest I would truly appreciate it. here’s the issue: coolant leak does not over heat no AC or heater drives great side Issues: 1-AC and heater are not working 2-coolant gets sucked into the engine but does not get returned to the reservoir tank 3-underside of engine is wet with coolant thoughts: 1-I’m thinking it’s the reservoir return hoses that may be compromised 2-thermostat is failing 3-water pump is failing has anyone dealt with this before? All helpful comments are welcomed and I’m video recording all my possible solutions so I’ll gladly dedicate a post to this once I solve to help future mini owners with this issue. cheers 🍻 to all and looking forward to more posts |
| All times are GMT -5. The time now is 12:27 AM. |
